Originally Posted by dcb
Pick a motor and a battery pack and a controller and do the math, and play with the gearing, rinse and repeat till you find a combination that can deliver what you want, then see if it is in your budget. It is a lot of number crunching. Less talky, more mathy
The math is what I don't know right now. I don't have the gear ratios for the bike transmission but I do know that the rear sprocket is something I could easily buy aftermarket to adjust a small amount. I'll call a bike dealer and see if I can get some more concrete info on the gearing.
