Escort
Shooting from the hip I'd say the angles on the hatch Kammback are too fast.Go to the Search EcoModder tool at the top of the page and type in Project:making a permanent Metro Kammback extension.-------- That will bring up what Darin has done.On page 2 of that thread you'll find a aerodynamic template you can model your Escort's from.We believe that if you follow the instructions you'll have attached flow for the full length of whatever you build and gas savings to prove it.Check it out.You're on the right path.
