I'd suspect adding a sway bar to the heaviest end, or maybe both ends of the car would help your sway situation, possibly better than changing wheels and tires. If the bar(s) work well enough maybe you could save the expense of changing the wheels and tires. And if you can spare the ground clearance, lowering really does help add stability too.
