Old 05-14-2010, 12:52 PM   #11 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
The one I built, which has been in use for years, is based on a rubber diaphragm. I think that the friction in a syringe would cause wide swings between on and off. I used a small,strong tin can from yeast, and bound the rubber drum-head on with windings of rubber strip. The vacuum hose fits on a soldered-in tube. The microswitch is bare, mounted on a hinge, and gets pushed into the drumhead by an adjustment screw. You could probably use a jar, and glue the vacuum hose into the drumhead.
