Even Todays Vehicles will hardly run if you "try" to disable it.. However if you say learn the routing of the vacuum lines (thanks alldatapro
) Then you can disable it as well as make the car run as normal because it runs poorly because it's technically a vacuum leak depending on how you try to disable. Not sure if any of this makes since to anyone else but hey a new born will do that too ya "lack of sleep and sanity" lol.
Trevor
