Congrats on the HX. I really wish they made a 4dr...
I'd try to find a way around using the stock cruise control. Lean burn mode on your HX is tripped out when it sees sudden throttle movements. By allowing yourself to loose a bit of speed on uphills and gaining a bit on downhills, you can keep it in lean burn longer and bump that mileage up even more.
