Be careful if your putting a brick or two in the water tank, some water tanks are not held to the wall very securely. The weight of a couple of bricks could be enough to pull the screws from the wall(Had it happen once).
Another option is to use either a zip-lock bag, or an old plastic paint tin, filled with water, in the tank.
