Old 07-18-2010, 01:49 AM   #3560 (permalink)
voltmatic automaton
Zoooooommmmmm.....what the!!??
Yes gents, it works!
The Logisystems power stage/Revolt Controller board is good! So after putting some low value resistors to parallel the gate resistors I can now drive the car and the heat is a lot more manageable.
It still gets to where the overheat alarm comes on but not NEARLY as quickly, I am working on the cooling setup to make it dissipate the heat faster. I was able to put some decent milage on the car today.
Are there any other changes I could make to the electronics to remove some of the heat?
Would the 15v supply we discussed help?
And thank again for everyones help, while it started out as all greek to me , it slowly is becoming a little ungreeked!
