Old 07-25-2010, 10:41 PM   #7 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
With turning the lights on and the car hesitating, I would say do your self a favor and check all the grounds. Disconnect the battery and trace all the ground wires check the ring terminals clean off all rust and dirt apply dialectic grease. If you have wiring diagrams this can be easier since you can see where and how your car is grounded.
If there is corrosion and dirt between any of the connections it can create a situation where it can get the electrical signal but the circuit is having to work harder to get it there.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
