I was so sad when my first dremel died. :-( I have a new one, and I have a multi-speed one, but I got it for free. Someone had it and the cord has a bad wire in it. So it will randomly not work for a while.
I've also gone through two angle grinders, some screw drivers, a hammer, ball joint puller, tie rod seperator and some other ones along the way.
Brucey while you posted in here. You have a header on your Subaru? Do you think it helped with acheiving better MPG? I really want to get one, but if its going to do more harm then good, I don't want to buy it just yet.
You're in WV so you know what I mean with the loss of speed and downshifts on the hills. I have a feeling a header would help keep the engine in top gear more often.
