Thread: My 2010 Aveo
Old 11-20-2010, 12:34 AM   #3 (permalink)
Thymeclock
Originally Posted by raver0789 View Post
So, I've had my aveo for about 8 months now. It's fully broken in and I've noticed that since then it's gotten better gas mileage.
I've done a copule of things to the car which have helped, but I was wondering about more.
1. I Inflated the tires to 41psi, which is a bit much, but the mileage increased drastically.
2. I heard something about how these cars like to run hot and get better mileage with heat. Can I install something to block of the air ducts in the front?
Hi and welcome. I too have an Aveo, but mine's an automatic.
Inflating the (crappy) tires to 40 PSI will help some, but it will give you a very hard ride.
If you want to see mods for grill block and belly pan, click here.
The grill block will help it heat up faster in winter. I leave the lower grill blocked off year round and only remove the upper block, and it seems to be OK.
