Question for you guys on the "compression test I did"... I couldn't get a reading off any three of the cylinders when I tried? But placing your finger near the plug hold, they sure pulled and displace air- I had all three plugs out when I did it, its that incorrect? After the fact, I thought "maybe I should have left the other two plugs in, while testing each cylinder...?
Maybe I need to try again, if I did it wrong?
Thanks,
Aaron
