What year is the car?
It seems like alot of cars have power steering and didn't really need it, so you might check around and see if there is a non power steering rack standard on other versions of the Rabbit that would bolt right on.
Also be aware that some alloy rims are heavier then steel rims, finding out the rim weight is always a good idea instead of just assuming that alloy rims are light.
