So i installed a 10 plate heat exchanger on my 94 metro today. Heated the fuel right up going in the throttle body. car barley drives. after further testing it apears that the gas boiling piont is much to low and all the fuel is turned to vapor before it reaches the injector and then the on time etc is way out of wack. long story short doesnt work. but i did leave the heat exchanger and hooked my washer fluid to it and now i have jet hot washer fluid, bonus!
