Hello again,
i finally build it using Arduino 0022, i had to remove comments from the #define useSDCard line after i had installed this library...
"arduino-filelogger.googlecode.com/files/FileLogger.V0.6.zip"
This is for logging to SD card that is added in the latest revision, i dont need this feature right now so i will try to make some changes to remove this dependency.
Thanks!
