personally I've got a water temp gauge, vacuum gauge and MPGuino, and I'll be adding an oil pressure gauge (never liked the idiot light system, I want to know pressure is low before its zero) Thought about the A/F ratio gauge but they're ~$200 and if you're not going to be changing the A/F ratio then they don't tell you much except to know when the car is in closed loop...
