Old 06-17-2011, 08:38 AM   #3 (permalink)
gone.st
Stylish hypermiler
Blueberry - '05 Toyota Echo Hatchback
Thanks for the reply!
Just before you posted, I decided to bite the bullet since the tracings seemed to match between v1.1 and v1.3. I guess force of habit I trust the PCB printing of labels more than the instructions online (had a bad experience once before!)
Anyways, wired it up properly stealing a floppy plug from an old PSU, found the VSS (btws, for 2004-2005 [maybe more] Toyota Echo drivers, it's Plug 3 from the left on the ECU, Violet/White wire)
Lit up perfectly this time! Had fun testing it out. Calibration to come.
I chose the heavier gauge wire for mechanical strength and the wire I was using had solid insulation which I wanted to use since it was going to take a fair bit of hot/cold in the engine compartment. I would hate for the insulation to fail, shorting the injector lead to ground and misfiring the cylinder
