The weak spot on the old Firefly/Sprint/Metros was thier frame. It is usually the frame that goes before the engine. If you don't know how to check it, the it should be gone over by a good bodyshop. The engines are all over the place with under 50K mileage because the frames didn't last. So if the frame is good, which is doubtful, than it's well worth fixing up.
