I had a 2 mile drive into work for the last 5 years.
What I would do is put a 110 volt space heater in the seat of the vehicle where it couldn't tip over and run the extention cord from it into the house, leaving it unplugged. Then all I would have to do is plug it in 10 to 20 minutes before I leave and the car would be nice and warm and all de-iced.
If the car is coved with iced on snow you might need up to an hour. After that time the door seal will be un frozen and the snow should be ready to fall off the cab of the vehicle with nothing more than the touch of a brush.
Something to look out for:
When it was got real cold the 2 mile drive would kill the batteries in my truck over the course of a week. The charging system worked fine, the glow plugs and cranking took more power out of the batteries than the alternator could put back into them in the short 7 to 8 minute drive.
Thinking ahead, when I built my new diesel engine I put 2 block heaters in it, 1 block heater was good, 2 should be twice as nice and installed a 1.5amp battery charger too. The combonation works very well for cold starts, leave the 1.5 amp charger on all night and plug in the 2 block heaters at least 15 minutes before I leave.
The next gasoline engine I build will have one block heater in it for sure.
