Originally Posted by mwebb
using 10w40IF AND I REPEAT IFit is approved by BMW for your application is the way to go
but
more important than the viscosity values are the BMW oil specifications which are applicable for that car/engine .
BMW LL01 afaik
so a off the shelf 10w40 semi synthetic is NOT acceptable and
there are many if not all oils that meet BMW LL01 that are not 10w40
ALL OF THEM ARE FULL SYNTHETIC and meet the
ACEA A3 B3 - A3 B4 specification as well as the BMW LL01 specification
i would contact BMW direct
OR
look in the BITOG forum in the European section to clarify exactly what the minimum oil specification for your car really is and never use an oil that does not meet that specification .
The oil meets the relevant standards as required by the owners manual.
and
mortals who are not lubrication engineers should never "blend oils"
unless they are salad oils for salads only
unless
unless you enjoy pain and internal engine work on older BMW engines
Old Tele man's response indicated that already,so i honestly don't see what your response adds to this thread.thanks for dropping by, in your whacky blue way,but I feel I've got the answer i needed after one post.
