How did you change the rear roll center on a single wheel?
the donor car had an RC higher then it has now. The front suspension of the donor car had an RC different then it does now. Hence, it has changed.
How are you achieving weight transfer with only one wheel?
When you go around a corner, weight transfers from the inside front tire to the outside front tire and the back tire.
You do know what a tire is?
