If it has the same 1.4kWh (1.3?) battery pack that the stock Prius has, the EV range will be similar.
The battery is 10kg lighter, and 0.3 kWh less than the regular prius.
Due to the additional weight and shorter gearing, on a slightly less powerful battery, it'll be a bit lower.
