I found my problem with not getting warm air into the Intake - it was a closure of the hose that I was using - I had it too close to the heat source - and it stated to melt close - once I solved that problem - I get consistant 60 degree temp into the intatake - so now I can go back to collecting data to analyze - glad I checked the hose first - I could have taken the whole setup off - hose last - only to find the problem at the end - just lucky I guess -
