Noob needs help with 91 Honda CRX D15z1 Conversion...
Im going for the gold here peeps and need advice! Ive got the motor and ECU control box but now have questions about putting a P07 ECU in place the P28 for the Lean Burn. (I know some of these questions will be silly to some but this is my 1st swap with my 1st Honda after owning American cars for years so please dont bite my head off...Im trying!)
1) Will the p07 use the same plug-ins as the p28 and if not what do I need? (is it more or less just plug and play)
2) Since Im going from obd0 to obd1, will the conversion harness from Rywire cover all the plugs- (electrical-distributor-injectors)- I need for the OEM wires that are currently installed.
3) Im having issues understaing the 5 wire O2 sensor and how it should be properly hooked up. Can anyone give me the 02 Sensor For Dummies crash course.
Thank you for any advice!
Paul
