Originally Posted by Ryland
That's only if you don't plug it in, the whole car is designed around the idea that the gas engine will rarely be used and if you look at the average persons needs, the gas engine should only start up a few times per year.
How often does the gas engine on your car start?
For a person who is retired or works close too home and does not go out a lot it may well be as you claim.
Outside of those ideal conditions the Volt falls miserable on its face, but i do not need to tell you that I am sure you must understand that as well.
After all it can only travel 33 miles on its battery.
my point is the car sucks.
