Old 04-17-2012, 09:39 AM   #1 (permalink)
Miller88
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Grille Block Makes Car Run Cooler??
I had some lower grille blocks (military duct tape) on my Focus. I did this is in the winter to help it get up to (and stay up to) temperature in the Winter.
I figure I'd save a bit of gas and it's better for the engine to reach the proper operating temp.
Yesterday it was 90 degrees out ... I decided to put my car in "Engineering Mode" to see how much hotter the car ran with the grille blocks.
I ran the same test loop, once with grille blocks ... once without grille blocks. For what it's worth, it was 1 degree cooler outside the second time
WITH 2 outer grilles blocked, middle open:
Running down the highway with A/C - 85-87C
Idling in parkinglot with A/C - 90C
After 10 minute off - warm start: 92C
WITHOUT any grille blocking
Running down highway with A/C - 87-89C
Idling in parking lot with A/C - 91C
After 10 minutes off - warm start: 95C
This ... doesn't make any sense.
I can think of two things
- Going down the highway, the air that is able to go through the radiator is going much faster since it can only go through one opening on the grille ...
- The temperature is just enough that the fan kicks on more and keeps lowering the temperature.
Input?
