Originally Posted by MetroMPG
The steering won't lock if you only turn the key back ONE click from the RUN position.
Is it possible you turned the car (computer) completely off by turning the key back too far, and that's what it didn't like?
Was this your first attempt at trying this - at 65 mph on the highway?
The ACC position on my truck is actually behind OFF, and you have to push the button to get it there. So clockwise you have ACC - OFF - ON - START.
I did find a similar situation on google from owners attempting to simply push-start an S-10. Apparently ANY time you start the vehicle, the key must be in the start position. So attempting to pop the clutch even in first gear, say due to a dead battery or bad starter, you must hold the key forward or the Security light will immobilize the vehicle... CRAZY!
