Evans coolant is fabulous. Eliminates nucleat boiling in localized hot spots exhaust seats and spark plug. If your going the electric water pump route consider circulating the coolant in reverse fashion. You can run about a point higher compression for a given fuel octane. Davies craig makes one that I've used with good results. The only drawback besides price is I've heard the viscosity goes way up in temps below zero deg. F
