Originally Posted by Daox
I've never had problems with the scangauge and heat. I've even had mine sitting on the dash that got so hot the plastic warped, but it still worked just fine.
I actually talked with Ron Delong, the designer of the ScanGauge. It was quite an interesting discussion and you can tell he has a passion for putting out a quality product and having satisified customers.
I wouldve gone with a scangauge but it was not in my budget to spend that much on a gauge, which is y i went with an UG. When i go to overhaul a vehicle in a couple years for mpgs i plan on making the switch to a scangauge but until then im stickin with the UG.
And to reply to sticking it in your gauge cluster i havae done it and it worked out quite nicely but the grand ams gauge cluster does not allow it to sit in front of the cluster
