Originally Posted by mattrich67
Timing question??
I did a quick check over and re checked my timing
My timing is at 11* on the red mark and that is with the distributor all the way rotated towards the front radiator.
Is the red mark the correct mark??
Engine at temp fan kicked on
Jumped timing connector engine light came on
The red mark is the one in the middle of the three clustered closely together, and it should be at 12* ... what makes you think that mark is at 11? I have heard that the problem may be with the timing belt itself. Have you replaced it? Are you sure it is installed correctly?
