Samurai speedo is mechanical cable. The problem is it runs off the back of the divorced transfer case. Therefore no drive from trans. I'm curious if the trans was used in other 2wd applications? Maybe a van or 2wd pickup? We didn't get them here, but I see a lot of them in NZ and OZ. There are several casting spots were it could go, so when I get it apart(needs bearings) I'll have a good look. Will check out the M/C tip as well. Thanks!
Roger
