Originally Posted by baldlobo
why are you looking at summit?
Originally Posted by _MADMIKE_
A quick google brought up a couple of links Summit Racing shows two 4wd kits,
McGaughy's Suspension Parts - 70010(2"/4") - $365.95
Ground Force Suspension - 9966(2"/3.5") - $569.95
I did a search, these two links popped up out of many. Complete lowering kits for a 4wd F150 of the 04-08 year range. It was an answer to
plasticuser original question of...
Originally Posted by plasticuser
What are my options for removing the factory lift and lowering the truck to a more sane level, aerodynamically speaking?
What are my options?
(I know this is a basic question. I've read F150 forums and not seen a clear answer, since everyone's usually going the other way )
rockauto, and there's about two lengths for the not struts.
(dimensions)
Those look like the dimensions for the stock shock options, which are different depending on what suspension package was placed on the truck from factory.
plasticuser is looking to lower his truck, a stock shock replacement is not going to lower his truck. Last time I checked RA only sells stock replacement type parts.
