Also keep in mind that EOC P&G using the ignition may cause you to "lose" some miles, because the odometer may not work while the key is off (in that period while you're waiting for the engine to come to a complete stop so you can switch the key back on). I found I was losing ~6% of my miles:
http://ecomodder.com/forum/showthrea...sel-24894.html
