Lower air density means you can have higher effective compression to produce the same level of power. This means less fuel to do the same work with lower pumping losses. Broad statements about what is best will not cover specifics of individual vehicles. Some will work better and others will not. Best to experiment with your individual vehicle.
regards
Mech
