Originally Posted by doviatt
The MPGuino has speed calibration in the setup screen.
Can you do this on a ScanGauge also?
as mentioned in scangauge II threads, yes. the key is to switch to the metric setting on the sacngauge and the gps you are setting it from. This will give a much more accurate adjustment. Then switch back to miles when set.
