Old 08-10-2013, 01:28 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by jakobnev View Post
You may not even need to spin the whole engine for testing spark.
Just:
1. Disconnect the injectors. (If EFI)
2. Mark distributor position.
3. Remove dist bolts and pull out the dist.
4. Spin the insides of the dist from the coupling and look for spark.
Edit: Might be good to keep the dist grounded to the engine while spinning it!
Since you have the distributor out of the engine, how do you spin it ? Surely you don't mean by hand ( me being dull again )
Are there any wires connected to the distributor at this point ?
By the way this is a 1993 Civic EFI engine.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
