Old 10-01-2013, 04:06 PM   #117 (permalink)
josemapiro
Originally Posted by Ardent View Post
I tested the button code change and it doesn't seem to address the glitch I'm seeing.
I have figured out the usage scenario where it crops up and a usage workaround though.[LIST][*]If a different button is pressed, it must be pressed slowly to not register as the same button press.
Probably is the same mistake that I mentioned with the middle button, causing it to behave as the previous button.
