If you look at "Converting Cali Civic VX to Fed (lean burn) VX" thread the wire harness NachtRitter makes uses the wiring harness plugs to make a o2 bypass and cpu connection.
Here is the 6 pin plug layout from that thread
bummer I can't post pic till I have 5 posts
