Originally Posted by etamax
I've run studded tires for years on the rear only. With adequate weight for traction, they will get through most everything. They really help with engine-braking too, which is important on snow and ice. Of course, the weather conditions that require studs will naturally hit FE a lot more than the smaller tire diameter will.
On dry or clean pavement, I imagine that having studs on the front might actually hurt performance. They will certainly change the steering dynamics, especially at higher speeds...
You are confirming most everything else i have heard. I am looking for some studless tires in OEM size. If i can find some I wont hesitate to put them on all four corners.
