I did a head gasket on a 4 liter jeep. Overall it was an easy job, but we decided to bolt the exhaust manifold on after installing the head. That job takes two people. One to tighten the bolts and one to direct him where to go.
Swapped the transmission on my 93 camry. Decided to drop it out the bottom when it clearly was meant to come out the top with the engine.
Had the same spark plug problem with my 02 Subaru WRX the first time. Took 2.5 hours. Second time I did it was because it needed new valve cover gaskets. Still need to lift the engine, but it is so much easier it is almost worth taking the valve covers off just for the plugs.
