If you click on vehicles, under the user names, one will see an expanded view. Most people put their modifications in there, on the vehicles page, and one can see the fuel log from there. Some people put their modifications into the log, too, so people can see trends.
Some people would like to add flags/entries to their fuel log for modifications...(hint)
My modifications for the Mustang are :
Scanguage II-2012/06/18; 18" OEM 2013 Mustang GT wheels with Pirelli P Zero tires-2012/07/03; Axle Back Exhuast, Front Fascia, Front Air Splitter, Side Splitters, Grille Block-2012/07/18; Cold Air Induction, GT/CS Rear Valance-2012/10/05; Air dam & Upper Grille Block-2012/10/18; Antenna Delete-2013/01/06; UltraGuage Install-2013/02/23; Kill Switch Install-2013/03/17; Premium Fuel Only-2013/04/13; Lower grille block-2013/05/11; Swapping Single Piece Air Dam for New Two Piece-2013/06/01; Full Underbody-2013/06/05;
Insight:
Upper Grille Block & Carpeted hatch- 2013/09/16; Lower Grille Block & Temporary Seat Belt Fix- 2013/09/17; Passenger Mirror Delete- 2013/09/21; Rear Wing - 2013/10/02; Manual regen switch (when engine braking) - 2013/10/10; S2000 Radio, S2000 Steering Wheel, S2000 Shift knob - 2013/10/18;Clutch "Engage" Switch - 2013/11/08
The Insight also has knew RE92s and a boattail, but I have to check dates so the entry is dead on. Both of mine have build threads you can search for using the search function, to see how I did it. None of my projects are new, and I often focus on ROI- many others pay much more attention to cosmetic details.
