Originally Posted by GreenFiesta14
Appreciate the advice. I was actually looking into the internal air blocks. Are the majority of those custom made like i'm assuming they are, or are there actually part distributors for those? what kind of mods have you personally done?
Plumbing pipe insulation, 92 cents a piece. I think the length is 6 feet. Probably something similar in Germany. Not sure if your lower grille is similar enough to mine but these worked perfectly. I slotted the back portion vertically to fit between the vertical supports on the lower grille of my 2011.
regards
Mech
