Another point is that you can gain BSFC and still lose overall MPG. Even if the engine uses less fuel per injection, and therefore less per revolution, your need more revolutions of the engine to go one mile with a lower gear than a taller one. So unless the gains from running the engine in its sweet spot are more than the difference between the gear ratios, you get better economy from running in the higher gear.
-soD
