Originally Posted by nemo
While a visual check is better than none it is best to use a volt meter. Just as easy to clean without checking and take very little time. I recommend you clean the ground using a small rotatory tool with with a brass brush, less likely to remove the coating protective coating from the connectors.
Brass is better than sandpaper or a normal wire wheel?
I do not think that I mentioned this:
