Old 06-11-2014, 08:07 PM   #11 (permalink)
spacemanspif
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Originally Posted by Baltothewolf View Post
I found one with a cracked head for 500 actually
Told you lol
ALL Saturns burn oil because the share the same short block and more importantly pistons. There are no holes in the piston where the oil control rings go. Therefore, oil gets caught in the control rings and gets stuck which then cooks it like crazy and causes the control rings to gum up and stop working. In a rebuild the pistons are either replaced with ones that have the drain holes, or the holes are drilled into the factory units. FWIW my friend used to be big in Scions and he said the Toyota engine that comes in the oldish TC and Camry (2az??) suffers from the same problem.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
