Changing the oil pan is pretty straight forward, and it'll be perfect timing with the exhaust off of the car. I think that the oil should be fine to re-use unless the oil pan is degrading particles into the oil.
What I would personally do is when you're refilling the oil, pour it through some sort of filter to be safe.
