Old 06-26-2014, 02:20 PM   #13 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Originally Posted by samwichse View Post
The 2x4s on the outside of the box... why not just "skin" the sides with a sheet of coro over the members like you did on the bottom. It should be easy, just staple gun it on the outside.
I'm actually planning to make each one a little more aero. I already have a 3/4 chamfer on the front of the 2x4 w/ some belt sanding. Next up is to cut some sheets of foam out for the tail end, then use the belt sander to give it the last bit of shape. I think this should be the most effective way to go.
