is it carb'd or fuel injected? if it's carb'd, i would check the fuel level in the float bowl. a low level can cause fuel starvation on corners due to insufficient fuel coverage of the jets.
only other thing i can think of is a problem in the power steering pump. maybe the valves that are supposed to open when turning left are stuck closed, causing the pump to bind, which creates resistance for the crank pulley. might be a long shot, not sure. if the power steering pump is run off its own belt, it would be easy to test though since all you would have to do is remove the belt and go for a drive.
