Originally Posted by RobertISaar
if it has gone this long, another week won't be the difference between an immediate demise and a million mile life.... but $20 and 30 minutes every 5,000-7,500 miles(i'm guessing what a normal interval for your car might be, follow your manual/community knowledge) is a drop in the bucket compared to the time and money spent swapping an engine only to potentially do it again if a swapped engine led a neglected life as well.
new oil helps, but an ancient filter doesn't. if i had something that leaked/burned more than a quart every 1,000 miles, i don't think i would change the oil often, but the filter would certainly be getting attention.
Yea, I'm not driving it right now due to the fact I don't want to drive it on the old oil and spark plugs. I just noticed the lugging when I took it to the mechanic to get the oil leak looked at, and then last night around town to check out the L/B with UG. Tbh it rarely ever does it, but it does do it once in a while.
[Edit]: While we are on the subject of spark plugs and wires, what would you guys recommend for best economy? I was told Iridium spark plugs and NGK wires are the best bet for that sort of thing, but I would like some more input.
