Old 10-13-2014, 01:05 PM   #15 (permalink)
Grant-53
Getting the ball bearings totally clean may be the hardest part if they are not loose. The other consideration is adjusting the play on the bearings. When putting the hub back together allow enough free play so that when the axle nuts are tightened against the frame there is no drag. make sure all the links in the chain are free also.
Waxing the chrome and spokes helps but if you have a store that sells CRC Marine Clear spray, that is awesome protection against salt corrosion. Rustoleum or automotive clear coats work well on all components and acrylic enamel is safe to use over most paints.
